Fusion Support
How does LOFT work..? I only get errors..
2 REPLIES 2
NVNDO
93 Views, 2 Replies
Hey community...
I`m sitting here since 3 hours trying to get LOFT to work without ANY success.
I tried face to face, guided by center-line, outer-line, inner-line, Circle to square, with less/more space in between, thicker, thinner walls, at an angle and I don`t know what else. I constantly get an error that something is not working and that I should try something else.
This is sooo frustrating... grrr... :´( Pls help..
2 REPLIES 2
davebYYPCU
in reply to: NVNDO
Try full solid.
Shell.
Loft is still unable to loft Wall type hollow profiles.
Loft a solid, then a second loft of the inside profile, as cut
will do the same as suggested above.
Might help….
NVNDO
in reply to: davebYYPCU
what a hassle...
I finally got it to work!!! @davebYYPCU  Thank you soooooo much   🙏🙏 🙏
I struggled a bit with the inner part, but extruding 10mm from top and bottom and then using the planes to make another Loft did the job. Now lets try in the actual project.
Thank you again!!
@NVNDO - this post has been edited due to Community Rules & Etiquette violation.
