How do you edit the size of an existing object?
Ken_NJ
Ken_NJ
New to Fusion 360 and the forum. I'm watching all the videos I can on F360 and search online when I encounter a problem. Could not find an answer for this. Once I create an object, say a rectangle, and the sketch is finished, how can I resize that rectangle if I need to. I just cannot figure it out.
I'm use to use 2D CAD programs, when you click on an object, you usually get a properties window where you can adjust properties of that object.
g-andresen
right click sketch > edit > double-click dimension > add new value
günther
jhackney1972
If you are use Capture Design History, right click on the sketch in the Timeline and choose Edit Sketch.
John Hackney, Retired
