How do you Create Small Text in Fusion 360?
arya.karthik.1
arya.karthik.1
Hi. I am new to Fusion 360 and I am wondering how to create small text. Right now I am creating a sketch and adding text in the sketch menu, and adding a textbox. When I type in the text, it takes up a lot more space than what is allotted for the text box. Is there any way to change the text size so that it does not exceed the text box boundaries?
jhackney1972
In the dialog box, where you enter the  text, you can change the size of the text as you desire.  The text box size is only a reference, you can size it to any size you desire either when you start placing the text or after entering it.  If you left click on the text box, you will see green dots on the corners you can left click and drag and you can even left click and drap of the box sides.  The text box also response to sketch dimensions and sketch constraints.
John Hackney, Retired
arya.karthik.1
Thanks. I realized that the height value scales the width appropriately.
