Announcements
How do I rotate & copy a sketch around a point
aliensqueakytoy
aliensqueakytoy
I'm a bit new and I believe I'm missing some key points here. I want to rotate this rectangle around the center point and copy it to create a pattern similar to the second & third images.
  I have tried to select the edges of the rectangle and use the Move/copy tool, but when I select the pivot point and try to rotate it, it doesn't have any affect.
jeff_strater
It looks like you used "Set Pivot" to change the pivot point, but never clicked on the check box to end Set Pivot mode.  I just did the same thing trying this out, so don't feel bad.  I always forget to exit Set Pivot Mode the first time...
Jeff Strater
Engineering Director
aliensqueakytoy
That seems like it was the problem! I can rotate it now. Thanks.
