Fusion Support
how do I know what is a sketch projected from?
2 REPLIES 2
rprovideo
125 Views, 2 Replies
This circle on the screenshot is referenced/projected from another item, as shown by the little projection constraint icon. I cannot really remember what, and I want to move it. Is there a way for Fusion to show it?
2 REPLIES 2
jhackney1972
in reply to: rprovideo
I will assume you are using Capture Design History and have a timeline.  If so, the video will show you the method of determining where the reference came from.  If you still have issues attach you model and let the Forum users take a look.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
davebYYPCU
That’s ambiguous-
do you want to move this circle,
or the projected source article?
The source - being moved is going to move this circle and keep the projected link intact.
You want to find the owner of the source point? will be a circle in an earlier sketch / body directly forward  / behind / or through this one.
Might help.....
