How do I join my bodies and removing the faces between them?
agnny682
agnny682
This may be a beginner's question but I've just made a shell out of my bodies, which kind of worked except that the faces between the bodies are still there. I know that they would not be removed by shelling the bodies, but I still wonder how to remove them since this project is about casting plastic - so the faces has to go.
Thanks in advance!
Replies (9)
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
TheCADWhisperer
@agnny682 wrote:
… made a shell out of my bodies,
Did you intend to Combine into one Body before Shell?
agnny682
I've tried to combine all the bodies together before Shell, but also with all the bodies separated - but nothing seem to work 😞
agnny682
Great! I've shared a copy of my work below 🙂
jeff_strater
is this what you are after?
Jeff Strater
Engineering Director
agnny682
That's right! Thanks! That's exactly how I want it to look, but I also want to add holes to the two piles like the front one. Could that be possible? When I have combined all of my bodies the shell function doesn't work and a warning pops up.
g-andresen
The reason for this is in Sketch 1, where there are sketch elements that lead to unclean boundaries to the adjacent solids.
günther
agnny682
Wow! Amazing! Thank you so much and especially for the helpful video! 😄
g-andresen
I recommend that the shell is  created after the outer fillets have been attached.
günther
