How do I get into Model mode?
Message 1 of 9
I am NEW. I have created a basic shape with holes that need to be cut out on a Shaper Origin. I have the plug-in for Origin but it doesn't show up. Presumably, because I am not in Model mode. But, i have no model mode. I am confusion.
Replies (8)
Message 2 of 9
julia.paganucci
Autodesk Support
Autodesk Support
hi @Anonymous ,
thanks for posting! it looks like you are in the UI preview. to change this, click on your name in the upper right hand corner, then click preferences. uncheck the highlighted box:
does this help?
thanks,
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 3 of 9
Got it! Thanks. I’m sure I’ll have more questions.
Scott
Message 4 of 9
how to do the same on Mac? there is no UV preview option
Message 5 of 9
g-andresen
the UI has changed.
You can currently activate the "old user interface" here. However, this only applies for a limited period of time. It is therefore advisable to make friends with the "new" UI.
günther
Message 6 of 9
evanbourne
all of the online tutorials, including your own, use the old UI.  How is someone new supposed to learn your program if you haven't updated your own tutorials for the new setup?
Message 7 of 9
davebYYPCU
For those of us who have used both interfaces, the changes are not that dramatic.
There is a change to Sketching Tools, but otherwise much the same, changed icons.
Model is now Design, with section tabs on the main screen now.
To get the sketching tools, you need to create or edit one, then the tools will be the same.
There are videos available that compare m the two interfaces,
If stuck, ask questions with sufficient info to explain the problem, in a new topic.
Might help....
Message 8 of 9
i dont  have in last version of fusion how is possible to set model ? thankz
Message 9 of 9
TheCADWhisperer
Model is now Design.
If you still have trouble - start a new thread and include screen capture images of what you see on you screen.
