Fusion Support
How Do I Fix This Fillet?
8 REPLIES 8
Message 1 of 9
glencandle
261 Views, 8 Replies
I have this object, which isn't perfectly square.  I want to round the edges, but no matter what I do the fillet gets all wonky.
Is there a way to achieve a perfectly rounded edge without the gap circled below?
Tags (2)
8 REPLIES 8
Message 2 of 9
@glencandle
Is something like the Attached what you are after?
Do you have a picture of something similar that already exists in the real world?
Message 3 of 9
Thank you for this, it is a lot better an option that what I was seeing.
I've opened your project file and it look like you were doing the same thing I was doing, but your result is different.
Any idea why?
Message 4 of 9
@glencandle
Do you have a picture of something similar to what you are attempting to model from the real world?
Message 5 of 9
Unfortunately there is not, to my knowledge.  But here is a mockup I made in Blender to illustrate what I'm after.  Notice how the bevel is consistent around the corners, where Fusion wants to do more of a rolling effect.
BLENDER:
FUSION:
Is it possible to achieve the Blender look in Fusion?
Message 6 of 9
@glencandle
Maybe this one?
Message 7 of 9
Yeah, with a finish that should work!
Thank you, didn't even think to apply the fillet in stages.  Makes perfect sense.
Cheers 😉
Message 8 of 9
So I actually just encountered another snag and once again I'm stumped.
I don't actually want the diagonal edge along each side to be beveled (refer to my Blender reference above).  But when I try and recreate what you've done it won't work unless I bevel that edge.  I've tried to bevel that area in different sequences but I can't get it to work.
Any suggestions?
Message 9 of 9
I also  just realized, using this solution, that the edges are now coming out with a curve, where they should be straight.
With Bevel:
Without:
