Hello, Im VERY new and trying to duplicate the attached .stl file but in a different size I need. The vertical tube part pops onto a 16mm pole perfectly but I need it to pop onto a 22mm pole. How do I figure out the exact cercomference of the tube(s) Vertical and Horizontal so I can try and recreate this bracket? I need to know how much larger diameter so I can just add that difference to 22mm correct? As for the horizontal ones I just need the cercomference they wont change in diameter. Thanks!
