How do I cut a specific curve shape across a cylinder?
I need to cut a channel into the side of a cylinder, with specific start and finishing points. And I need it to have a specific shape, so I need control over that as well.
I want the channel to run from point A to point B, which is at the top of the cylinder but only 45-degrees around the circumference.
The Coil tool does not have enough control to pull this off as you can see, but essentially that's what I'm trying to do.
What are other techniques for doing this?
Ideally I'd like to sweep a profile along a curve with the exact shape I need, but I don't know how to sweep a curve along a three-dimensional face.
NOTE:
I have tried a 3D sketch by projecting the top of the cylinder, snipping it down to match up with the points, then using a Coincident Constraint on the lower point. But this presents two issues: 1) the curve pushes away from the surface of the cylinder in the middle because the angle is no longer right, and I still don't have control over the shape of it after that.
Is there a way to create a curve with more control?
