Fusion Support
How do I create a Construction Plane at this point?
7 REPLIES 7
Message 1 of 8
glencandle
215 Views, 7 Replies
I would like to create a construction plane (to create a sketch) that is at a point, but at an angle to three adjacent faces.  I can't figure out how to do it.
This is the point and the dimension along XYZ that I want to create the plane:
Using Blender I've created the following Boolean to illustrate what I'm trying to do, which is create a sketch so I can extrude a cut into the corner:
I can create sketch planes angled to faces and edges, but none of them get me to where I want to be (per the references above).  Would love some help, thanks.
7 REPLIES 7
Message 2 of 8
seth.madore
in reply to: glencandle
Give this a try, there's likely other ways of accomplishing the same result 🙂
Seth Madore
Message 3 of 8
seth.madore
As you drag "Plane along Path", it will "snap" to the projected sketch point:
Seth Madore
Message 4 of 8
g-andresen
another way
günther
Message 5 of 8
seth.madore
in reply to: g-andresen
Yep, just a bit simpler than my approach 🤣
Seth Madore
Message 6 of 8
g-andresen
With a cube it is even easier
günther
Message 7 of 8
@glencandle
If you know the XYZ dimensions you do not need Plane or Rectangle.
Message 8 of 8
glencandle
Wow, thanks so much for weighing in you guys! These are all great solutions, totally just expanded my understanding of how to CAD 😉
