Announcements
How can we let "fx Change Parameters" show Model Parameters such as width and height of a rectangular object?
minourat
minourat
I created the following rectangular object:
Fort his object the Model Parameters I need are not shown now. They were shown Until a few dasy ago.
The parameters I need are Model Dimentions d2 and d3. Why are they not shown now?
These parameters were shown until a few days ago. The same problem occurs for a cylinder too.
The commands  I used to create the rectangular object are
 select Surface => Sketch > select XY plane => select 2-Point Rectangle
=> Finish Sketch > select Home > select Create then Extrude => (change to Solid) > Create > Thicken
>> select 2 mm> select 4 faces >
I will appreciate any help.
g-andresen
günther
jeff_strater
the top image of the parameter dialog that you show does not contain a sketch.  It looks as if you have deleted the sketch.
Please share both the current version of the design, and a previous version of the design that you believe is correct.
Jeff Strater
Engineering Director
minourat
I watched you video carefully and noticed that you are mesauring the width and height of the rectangul. I then realized that only measured dimentions are listed as Model parameters.
I could solve my problem based on your video. Thank you very much.
