Announcements
How can I split the body of a mesh in only a small section?
williammhuber88
Community Visitor
williammhuber88
Community Visitor
Community Visitor
I have a laurel wreath model I need to split into thirds and the split body function wouldn't be optimal. I only want to cut the stem of the model while leaving the leaves intact. Furthermore, I'd prefer to make the cut in a "V" shape.Screen Shot 2022-03-07 at 4.33.10 PM.pngOriginal model.Screen Shot 2022-03-07 at 4.32.41 PM.pngPreferred way to cut.Screen Shot 2022-03-07 at 4.32.11 PM.pngProbably easier but less optimal way to cut.
hamid.sh.
With a mesh your options are limited. I would have designed this with Solid tools from scratch. Shouldn't take long because it's mostly pattern and mirror.
If you are insisting on editing this in Mesh environment; Modify > Plane Cut will cut by planar face only and it will also cut the leaves, so you need you Combine afterwards.
Hamid
dsouzasujay
@williammhuber88,
Can you attach the *.STL file here?
I see its possible to cut as you have shown in image.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
