Honeycomb pattern with rectangular pattern makes Fusion 360 unresponsive.
I am getting rather frustrated creating a simple honeycomb pattern. The pattern was created as a sketch using rectangular pattern which seems to be a performance killer.
I also tried this out with rectangular pattern outside sketch mode with feature but it equally slows down Fusion and I am unable to use partial pattern on the edges + suppression cannot be edited.
Is there a better way?
g-andresen
Note:
1. Patterns should never be created in Sketch mode, except for those that have few elements.
2. in your case create 2 polygons > extrude/cut them > create pattern (feature or faces) > option: indentical or optimize.
Furthermore, it should be considered not to use the polyons but the separating bars.
A structure of this type is then placed over the cutout and joined to the remaining body.
it´s only german language, sorryit´s only german language, sorry
günther
MoshiurRashid
Hi
Thanks for posting. As I can see, if you want to keep the design history, there is no other way than just reduce graphics performance by following this link .
If you don't want the design history let me know.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
TheCADWhisperer
@Anonymous
It is usually better to Pattern Features rather than Sketch elements.
(See Attached)
g-andresen
in addition to my contribution #2
I extruded the profile in surface environment and thickened symmetrically. This gives me more variation options. The individual elements of the pattern were combined and then, after they were inserted into the cutout, blended with its outline. The element can then be saved separately and used in other designs with modification if necessary.
In the attached file I used the pattern type "Faces" because I had the best experience with it (speed).
But also try "Features" and the compute options "Identical" and "Optimized".
günther
Screencast
