Hole Tool, Hole Callout BUG.
If you use a non standard pitch for a threaded hole the hole dialog doesn't update the diameter to match the minor diameter. The hole size is for 1/2-12 UNS. This is a long time bug and in the model workspace doesn't really matter because the model will have the correct size. Also note the leaders in the dialog go across the input boxes. Reported this last week but the post sunk without an answer!
The problem is in the drawing workspace the wrong size is used in the call out. Below you can see the hole diameter in the parameter manager is the same for a 1/2" 12tpi and a 32tpi!
And in a 2d drawing the size in the callout for the 32tpi thread is wrong. Adding a diameter dimension on the left gives the correct minor diameter.
Mark
Mark Hughes
Owner, Hughes Tooling
