Hole table error
Having an issue with the hole table feature on 2D drawings. For some reason on the last few attempts of using this feature, if there are several tapped holes only 1 of them appears in the table with the correct dimensions. All the other identical tapped holes show what i presume is the core drill size for the relevant tapped holes. I've checked and redone the model several times using the hole feature but the error never changes. If i have 4 identical tapped holes for example
