Announcements
High DPI Scaling Quirks
Message 1 of 1
I've noticed some strange quirks when using the High DPI preview feature. These issues happen with the feature checked on and go away when the feature is checked off.
-The right click Diameter Dimension does not change the dimension from a radius to a diameter.
-Very frequently sketch dimensions disappear while editing a sketch. They can can be shown by toggling the "show dimensions" checkbox off then on again.
-The right click drag menu loads very slowly (a couple seconds) before showing the wheel options.
If I turn high DPI scaling off - what display settings do people recommend to avoid the "zoomed out" look of a 4k monitor but not run into issues with text being cutoff in prompt windows? The high DPI setting seemed to fix that issue very well but it creates all these little performance quirks.
Thanks!
Replies (0)
