Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
High DPI Scaling Preview Disables Touch Controls
2 REPLIES 2
ajamesut
194 Views, 2 Replies
I have a 2 in 1  laptop with a high-resolution display. Upon enabling the High DPI Scaling preview my touch screen controls no longer work (regardless of if use high-resolution graphics is enabled under the display menu). Other than that things seem to be working fine.
I will say that using the high dpi setting really does make this program look way better. Once all the toolbar icons are updated to match the clarity of the rest of the program this will look amazing!
Tags (1)
2 REPLIES 2
lance.carocci
in reply to: ajamesut
Thanks for the report, @ajamesut. Would you please give me a rundown of your display settings or device specs?
Namely:
  • Display native resolution
  • DPI scale %
  • Year/Make/Model of device
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
ajamesut
in reply to: lance.carocci
Resolution: 3840x2160 (Native 4k)
Windows Scaling: 300%
Computer: Inspiron 7391 2 in 1
Interesting note: Tinkering around with scaling in the windows display settings I discovered that at 125% and 100% scaling touch controls became re-enabled (without restarting fusion).
Also, I didn't mention this when I initially reported the problem but touch controls don't work at all in any fusion window with this preview. Clicking the exit button on the program doesn't even work with touch. However, all other programs continue to respond normally to touch input even when fusion is open.
