Fusion Support
High DPI awareness issue: July 2023 update
3 REPLIES 3
Henrik_Pankoke
159 Views, 3 Replies
It does not look like the Design history bar has had the update
icons and text is blurry
Tags (1)
3 REPLIES 3
Hi @Henrik_Pankoke, are you using a fractional DPI scale, such as 175, 250, 325%, etc? It seems that by enabling DPI scaling, it has changed the way these icons handle fractional scales. If you are able to switch to a whole integer scale like 200%, that may be the easiest workaround for the moment.
This is logged internally as FUS-133068 and FUS-134266.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
In fact I am using 150% scaling to run 4K on a 32" monitor.
Setting 100% makes the icon so small that I can not  see imperfection in the icons and text, but 200% enhances blurry.
It is not a mayor issue for me. I just wanted to point the issue out to have it corrected over time.
Thank you.
I appreciate the report, @Henrik_Pankoke! I apologies for the pixilation - we intend to improve this experience.
Lance Carocci
