High CPU-Load on MacBook
Hello all,
i´ve got a little problem with Fusion360 on my 2018 MacBook Pro:
Fusion graps up to 3 Cores of my CPU.
As soon as Fusion is started the CPU-Load is rising, also if only an empty Workspace is opened.
Even in background, without doing anything in Fusion the load doesn´t go under 50%.
I found some old threads about similar problems on mac, caused by an old 3DCONNEXION driver or the OpenGL-Renderer. Indeed i had this old driver, but I deinstalled it without any effect to the problem. Also a reinstall of Fusion didn´t helped.
Any idea how to solve this Problem?
My OS is Version 10.15.6, Fusion Version is 2.0.9006
Thank you!
BR from Germany,
Tobias
EDIT:
[GPU-Informationen]
GPU-Gerät: AMD Radeon Pro 560X
GPU-RAM: 4096 MB
GPU-Treiber-API: OpenGL Core Profile
[Einstellungen für Grafikeffekte]
Hochauflösende Grafiken verwenden: Aus
Anti-Aliasing: Ein
Umgebungsokklusion: Ein
Objektschatten: Aus
Schatten auf Ausgangsebene: Ein
Reflexion auf Ausgangsebene: Aus
Auswahl Anzeigestil: Normale
Transparenzeffekt: Bessere Leistung
[Effekte beschränken, um die Leistung zu optimieren]
deaktiviert
