Hi Autodesk - what does it take to get attention to long standing Mac OS install and UI issues?
Hi - bringing some long standing gripes to the forefront in hopes of renewed traction toward a resolution.
1 - Mac installation issues
- The app is a non-standard install that does not follow Apple convention or any common sense. The application is installed in a non standard location and places data outside of the standard apple prescribed locations.
- The application does not appear in spotlight search and has to be manually tracked down and dragged to the dock. It may or may not show up properly in launch pad, as the icon there often points to an orphaned executable.
- Often times when there is a software update, the existing dock icon breaks and the new one has to be manually found and added or two dock icons show up, with one being correct and the old one broken (orphaned)
- the latest (IMHO unstable) update creates a NEW dock icon every time the application crashes and/or randomly creates a new icon after closing F360 and re-opening.
- on random app shut downs, the app can NOT be opened "The application 'Autodesk Fusion 360.app' can't be opened." is the message. The icon points to the wrong place. Sometimes the App Launcher icon can be used to recover, other times a full re-install must take place, likely due to broken dependencies from the wonky update process.
- EVERY TIME any of the above problems occurs, one has to remember to right click the 'new' dock icon and select "Keep in dock", as the icon is 'new' and defaults to removing itself from the dock when closed (or there is a crash) and it replaces itself again. Browsing to a hidden app library to retrieve the latest executable link is extremely frustrating.
Given the above issue with a new dock icon constantly being created and orphaning the existing one, I have a feeling that your "fix" for this whole mess was to attempt to use script of some sort that automates copying the "new" icon to the dock. This (clearly) is a disaster.
2 - Graphics and UI persistent issues.
- Modal windows stealing focus for Fusion360 when it is open in the background or minimized.
- Popup advertising for plugins or whatever else you want to convey cause above behavior. REALLY?!
- Change of internet connection, going offline, etc causes above behavior. Why does your application not use the built in apple notification interface? There is no excuse for a modern application to steal GUI focus. This is not real-time life safety software - NOTHING IS IMPORTANT ENOUGH TO STEAL FOCUS.
- Like above, any tool dialog left open generates a focus stealing modal dialog warning that the file can't be autosaved. This dialog steals focus and WILL NOT stop popping up until the offending tool is cancelled or closed.
- The component browser misbehaves and clips (appears above) ALL open applications from time to time. This is triggered from the above events and other unknown things. F360 should NEVER steal focus or clip other interfaces with its own graphics.
3 - Pan, Zoom, Orbit
- Once a tool dialog is open pan and zoom via touchpad breaks or becomes basically unusable. Once can no longer pan effectively and zoom becomes super sensitive. This happens with touchpad - and is very frustrating. A bit different than the loss of orbit issue - but may be related. Overall though, the touchpad is just not really usable for F360 on a Mac for as long as I can remember.
Both the Mac installation issues and focus stealing issues are the result of application design that does not adhere to longstanding UI and/or OS vendor standards and best practices. It does not appear from this perspective that any effort is being made to resolve these issues.
I don't think it is at all unreasonable for your customers to expect an application of this size, maturity and budget to install and behave properly on a modern operating system. You have known about these issues for years and they have no been fixed. In fact, they continue to get worse over time and not better. The only thing that has changed is that Autodesk has stopped responding to threads regarding these issues.
This application is extremely frustrating to use on the Apple platform.
