- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I use Fusion360 for furniture design so generally things stay fairly simple. I rely heavily on the Paramatrics and never have issues.
I recently decided to scrap a complex project that had gotten too messy and start over with a different method in which I created an origin body, which has the outer dimensions of my furniture, and construct mid planes in every axis based on the parametric values of the origin body. I sketched directly onto this origin body and extruded new bodies as needed, almost always symmetrically from the applicable midplane using my parametric values, and had the basic structure of the furniture done very quickly.
I tested the project by changing the basic metric which is referenced by many of my parametric values by 1mm , and was surprised to find that while the outer dimensions changed accordingling, the separate bodies where joined or cut and no longer recognisable.
I'm wondering what I did wrong.
FYI : I didn't actually start a new file. I deleted everything in the original and kept the parameters.
