Announcements
Help with offset! Trying to make an offset for a cookie cutter
Hi all!
I am new to Fusion 360, but I am trying to design cookie cutters. I followed a tutorial on Youtube, and inserted the image I wanted to turn into a cookie cutter. I traced the image using Fit Point Spline. The video says the next step is to create an offset. When I try to do so, it tells me to select the curve, but I am not able to do so. Will you please help me create an offset?
Thanks so much!!
Meagan
dsouzasujay
Hi @Anonymous ,
Can you attach the design that you have created in Fusion 360? You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Of course - here it is. Thank you!!
dsouzasujay
Hi @Anonymous ,
The sketch is created in Iso view.
Iso view looks like this:
The same sketch, Top view looks like this:
That's the only reason you cant offset the sketch.
When you are creating sketch, In the sketch palette,
  • Select Look At and then create a sketch.
  • Also, Uncheck 3D Sketch
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
TrippyLighting
@dsouzasujay wrote:
Hi @Anonymous ,
And you feel the tight variable radii of this continuous spline would not prevent it being offset ?
TrippyLighting
I've attached a model with one approach to this post. I created the outline with 3-degree control point splines, but you can use fit-point splines as well. This can be offset or extruded and shelled to a degree.
