Announcements
HELP!! Fusion Performance Error
silvia_guerrerosmith
I keep having issues when trying to Edit an Extrusion on a design. This time, when I clicked on the error, it opened up the box in the image. I already checked the "limit effects" option a while ago and it keeps happening. Once I make the change I need to the Extrusion, the file freezes at around 65% computing and I have to force quit the program. HELP!!
jhackney1972
You need to attach your model causing this issue and indicate what you need to do.  The Forum cannot do much with out the model and your operations
John Hackney, Retired
TimelesslyTiredYouth
IDK how CPU intensive Fusion is but do you have any other CPU intensive software in the backround...
Could help prgression....
