While using the trace function under 2D I am getting two different results and can't seem to fix it.
The issue: Tool center line is not on sketched centerline.
First picture below on left is tool is offset from centerline, the next pic is on centerline.
I have one program that the same tool is directly on center of the sketched number. I have another program that it is offsetting to the side, and I am guessing it is offset similar like a contour pass, calculated for tool diameter and touching the side of the tool.
It should be noted that they are the same font using the same tool. I know someone is going to ask for the file but I cant, it's under NDA. 😞
If someone could point me in the direction where I am going wrong. Thank you for your time in advance, Respectfully, Sean
