I have been working on a model over several months with no issues.
I did the upgrade this morning, opened my model and continued working.
All of a sudden all of my artefacts aren't displayed. If I go into the time line are do an operation such as edit and extrude, it gives me an error suggesting the bodies don't exist..
If I create a new sketch and do an extrude it works and displays ( Body858 ) - but nothing prior to that displays.
I was able to go back to a saved copy and reproduce.
Created a Offset plane.
Created sketch on that plane ( profile for sweep)
Created sweep (cut) using above profile and path an edge of a body - no problems at all
Created another offset plane
Created same sweep profile as above
Created sweep but this time the path was along two lines that were from two bodies.
The cut operation went ok, then I saw all visible bodies take on a what looked like extra lines, some sort of corruption I gather, then all of a sudden nothing is visible and Ctrl-Z has no effect - from that point on the model is buggered.
Latest version of Fusion (this morning upgraded)
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
