hello, I have fusion 360 and the program just started being very slow. Is there a fix for this?
CRIDERFAB
CRIDERFAB
Community Visitor
Community Visitor
hello, I have fusion 360 and the software just started being very slow. Is there a fix for this?
jhackney1972
This could be caused by many factors.  We could start by seeing what you are modeling and your methods.  Please attach a model exhibiting the "slow" response.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
dsouzasujay
@CRIDERFAB,
If the slowness is not due to design/model, then.. do you mind sending up the complete Diagnostic Log Files?
You can get them from, Help -> Support & Diagnostics ->Diagnostics log files. This will generate a zip file that you can upload.
At this stage, I assume you are running Fusion on a newer version 2.0.12392.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
