Announcements
Heidenhain 426 post processor bad toolpath
reisaXWBA5
reisaXWBA5
Hi.
Im trying to machine  in a Heidenhain 426 control with the toolpath generated with Fusion 360 and the simulation at the machine was bad.
Some  of the circular interpolations make no sense.
I attach photos of the Fusion 360 toolpath and the simulation on Heidenhain 426.
¿Why do i get those bad moves?¿The circular interpolations are not correct?
(I had the same issue on a Fidia control and the solution was...... manage IJK in absolute values and circular interpolation only on G17XY plane, linearising other planes and helicals.)
¿What can i do?
¿Can i configure the post processor for  write Linear moves only? To make all the curves formed by lines.
 Please, i have a big milling machine waiting for an answer.
Thank you.Fusion 360 generated toolpathFusion 360 generated toolpathHeidenhain 426 simulationHeidenhain 426 simulation
boopathi.sivakumar
Hi @reisaXWBA5..
To linearize the arc moves and helical moves. open the .cps file in any editor and search for this two line in any editor
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
 And make it to something will linearize the arc and helical moves
allowHelicalMoves = false;         // False to linearize the helical moves
allowedCircularPlanes = 0;         // disallow any circular motion
if you want to have arcs only on XY you can also set the post to do so for that
allowedCircularPlanes = (1 << PLANE_XY);
Let me know how it works for you
Boopathi Sivakumar
Senior Technology Consultant
reisaXWBA5
Thank you for the rapid answer.
The simulation seems ok.
Im going to start machining in a few moments.
