Announcements
Hard to describe - while sketching, new entities are intermittently ignoring input dimensions
erfl5555
erfl5555
Hi - Not sure how to search for this problem:
In sketch > Draw a center point circle> click to place center point and drag a short distance to make the numeric input entry popup appear> type my dimension> enter to finish the circle
This leaves me with a circle with the dimension where i left the pointer, not the number I entered.
Occasionally it will work correctly, but this is unpredictable.
I have also had this happen on a center point rectangle> click to place center> drag>type dimension in first side>tab(side resizes to the entered dimension)>type second side dimension>enter (second side ignores entered dimension and uses pointer position instead)...
This was not a problem previously
PS I can change the dimension after, but this is not efficient
davebYYPCU
This is a known problem for Windows 7 users,
there is a fix for those people,  Search Win 7 compatibility mode.
but if not Win 7 that is a new problem to tackle.
Might help....
erfl5555
Yes, still stuck on Win 7 (for various reasons)
I will look into the fix
Thanks!
NecroClutch
Observer
Observer
I see this is a problem on windows 7 but I got Windows 10 and am having the same issue, the manual input from keyboard when making sketches is getting ignored. I make a circle 3.2 mm and press tab to lock it in and it ignores it, sometimes I put a number in and it keeps erasing it, or it will ignore it and just take where my pointer is on the screen. I have to remake a line/circle/square 3 or 4 times to make it work. Really tedious and very annoying bug.
g-andresen
There are numerous entries on this topic, including current ones.
The problem is being worked on.
Günther
seth.madore
Good news everyone! This issue should be fixed with the update that rolled out yesterday. Sorry for the annoyance...
Seth Madore
