Fusion Support
Haas Chip Clean (E...) in drilling codes
2 REPLIES 2
Matthew.Magnaghi
147 Views, 2 Replies
I work in a shop with Haas VF2ss and VF4ss.  They have the ability to reverse the spindle in between drilling holes with the E command.  I'm not very fluent with editing Post Processor Codes, and trying to figure out how to enable that function to true.  Or am I missing something more basic, in the post parameters to force this function?
I would actually like to just have it forced to chip clean after every hole, without having to toggle a switch every time I create a new hole pattern.
Any help would be appreciated.  thanks-MJM
2 REPLIES 2
Hi @Matthew.Magnaghi
you can add a action command "CYCLE_REVERSAL"  before the toolpath that should get you the code
Boopathi Sivakumar
Senior Technology Consultant
That did the trick.  Thank you, still new to this Fusion 360, learning new tricks every day.
