Announcements
Guide Rail problems with Loft tool
Message 1 of 15
Hey guys, if ANYBODY has a troubleshoot solution for this, that would be really, really appreciated. Every time I try to add guide rails to my whiskey bottle model, it always tells me that they're not attached to all profiles. Note that I've already tried adjusting the profiles and rails like ten times already, started over and tried using different specs, and made sure that my fit spline matched up with my straight line that makes up the curvature and stem of the bottle. Any suggestions?
Replies (14)
Message 2 of 15
g-andresen
I do see some (white) points that could indicate missing connections.
But for an assured statement you would have to share the design.
günther
Share:
File > Export > save as f3d locally > attach to next post
Note:
Please embed images in the text in future. You can do this by clicking on the camera symbol in the editing window.
This saves readers from having to switch back and forth between text and images to understand  the content.
Message 3 of 15
davebYYPCU
Sketch > Project > Intersect,
gives you purple dots to connect to, without that process, it's unlikely to be successful.
Might help....
Message 4 of 15
Thanks dude, I'll give it a try!
Message 5 of 15
Thanks. I'm new to this too, so I'm still trying to get a hang of the basics. Take a look and see how I can get the rails to connect to the profiles.
Message 6 of 15
davebYYPCU
Your rail sketch did not have any purple dots,
rails should snap to points in it's own sketch.
Sketch > Project> Intersect,
hide profile sketches and looks like this when done, (connect the dots).
Loft will not fail after that process.
Press OK
Might help
Message 7 of 15
jenpearsondesign
Community Visitor
Community Visitor
Having the same issue. How do I add the purple dots as a guide?
Thank you,
JP
Message 8 of 15
TheCADWhisperer
P for Project (Geometry).
Message 9 of 15
davebYYPCU
So message 3 above is how, (Selecting articles the pierce the sketch plane)
message 6 is what you get.
Might help....
Message 10 of 15
jenpearsondesign
Community Visitor
Community Visitor
Error with the spline not snapping to the four planes.
Message 11 of 15
davebYYPCU
We need your file so we see what is working or not.
See Message 3, and 6, above.
Message 12 of 15
tedesco.jg
I'm having a similar problem getting a model airplane wing. After choosing the wing root profile and rails the loft tool accepts them without error. After choosing the second profile, the tool shows an error in two rails that had already been accepted. At this point I canceled the operation and started another one, this time not choosing the two rails that had produced the error in the first operation. In this second operation the loft tool pointed an error in two other rails that had already been accepted. I'm not sure what to do to be able to produce the wing panel. If anyone can help me, that would be really, really appreciated.
Thanks in advance.
The photos in the Pictures.zip file are as follows:
Untitled1.png - after choosing the root profile and rails.
Untitled2.png - after choosing the second profile, showing the error.
Untitled3.png - zoomed in on the part where the error is shown.
Untitled4.png - the second operation, after choosing the profile and rails, except for those that produced an error in the first operation.
Untitled5.png - in the second operation, after choosing the second profile, showing the error.
Untitled6.png - zoomed in on the part where the error is shown in the second operation.
The project file is Wings v3.f3d.
Message 13 of 15
TrippyLighting
Lofting does not allow for hollow profiles. Loft the entire profile and then shell it to the desired thickness.
A general recommendation is not to add problems to already closed threads.
Message 14 of 15
tedesco.jg
Thanks TrippyLighting for the answer. I am grateful that you replied.
I've made several wings this way and I've always had positive results even with the profiles being made this way and having several rails between the two profiles. Attached is a project where I used this technique. Only this time it's not working. I can't tell if this is a result of the last Fusion update or it's some sketch building pattern that has changed because all the wings I've ever drawn were before this latest Fusion update.
Did you use rails in generating the solid of the project you sent me?
Thank you in advance for your reply.
Message 15 of 15
TrippyLighting
I did not use rails as can be seen when opening the design and looking at the lofts 😉
I deleted the rails from the design attached to your last post.
As I had expected, it still works perfectly fine without the rails. For a straight loft between two profiles, rarely are rails needed.  And if rails are needed the amount is usually very low. Less is better when it comes to lofts.
It is very unlikely that the last Fusion 360 update changed anything in the loft tools, as changes to it are pretty rare.
