Announcements
Grouping lines in a sketch prior to applying patterns/mirror
heathVUT53
heathVUT53
I've learnt on this forum that there's no "group" function in Fusion 360, so I'm interested in what the best practice alternatives are.
How would you apply a mirror or pattern to a collection of lines? Using a selection set is easy but makes a mess from a simple design.
jeff_strater
Selection Set is the answer for how to create a "group" of items in a sketch.
Yes, mirroring in a sketch creates a mess in multiple ways - visually, and performance.  Instead, it is recommended to do the mirroring in the solid environment.  Make your solid out of the sketch you have, then mirror that solid.
Jeff Strater
Engineering Director
heathVUT53
Good to know, thanks for the response. Sounds like a useful workaround, but a bit counter-intuitive to me since I typically sketch a cross-section and think of Push/Pull as an extrude operation. Push/Pulling first and then mirroring means I have to define my length before I have a complete cross section, which feels a bit backwards.
But it's a good tip and I appreciate it.
hamid.sh.
You can first make a surface using mirror and pattern and then use it for extrusion. This way you have cross-section first, from a simple sketch (pardon the arbitrary profile, I just made it as an example):
File is attached.
Hamid
heathVUT53
Oh, I wasn't familiar with "surface". That makes a lot more sense! Thanks for taking the time.
Specifically you need to add these steps right?
  1. Close the sketch to form a face (that is, add one more line where the sketch mirror line would have been).
  2. Create a Surface Patch.
  3. Then go ahead and apply the mirror/pattern to the Surface.
  4. Finally, Stitch the surfaces together, assumedly to remove the adjoining lines.
hamid.sh.
Right! You got it. Just don't forget to make your sketch fully-defined.
Hamid
