Announcements
group components so they move together but without touching each other
cowboytyler669
Observer
cowboytyler669
Observer
Observer
I have two components that need to stay perfectly aligned and move together without being superheated, but the components aren't touching. I don't know how to do it. I have a picture below with the two components I need to move together but without touching. they are for a modular design, and I need to be able to copy them and move them around without separating, and keeping the same alignment to each other.
ThanksScreen Shot 2021-03-20 at 6.29.06 PM.pngScreen Shot 2021-03-20 at 6.29.15 PM.png
davebYYPCU
Put them in an Assembly > Rigid Group,
You have too many Move and Capture Positions in the timeline for best practice.
Fix the yellow icon, too.
Might help...
cowboytyler669
Observer
Observer
I will try that.
Im new to Fusion 360 and every time I try to add a new component or something a pop up shows and says I have to capture my position first, I’m not sure how to go about that. And as for the yellow on my timeline, I have no idea what that is or how I get rid of that.
thank you
davebYYPCU
Design Dependent for everything you do after opening Fusion.
Adding any component - it's free (click drag) to move until you prevent it,
(if it moves you are asked if you need this new position, or revert back to where it came from, saving new positions is not best practice)
then use Joint to put it where you want it to be locked.
Right click the yellow timeline icon, select Review Warning.  That feature in your timeline is sick, can be fixed and should be fixed.
Might help....
cowboytyler669
Observer
Observer
Will do. Thank
you
