Announcements
Grey screen in animation window. Can't see models
jkoturner
jkoturner
Windows 10 PC.
After the latest update Fusion 360 loads up showing the normal menu icons but with a dark grey workspace. The origin is not visible and neither is any of the model (yes it is selected visible and active).
If I select the model it appears as a blue see through object but disappears if nothing is selected.
I have 'repaired Fusion 360'. No change
I have uninstalled then reinstalled Fusion 360. No change.
Any help appreciated.
Cheers,
James.
andy_uk22
I have the same problem, unable to see models in design workspace. This has happened since last update. All drivers are up to date and I have even tried selecting Direct X11 in the Preferences/Graphics section in Fusion 360. I have re-booted my system many times but to no avail. Can someone from support please help. I am currently unable to use Fusion 360.
g-andresen
Do a Clean Uninstall with Service Utility
günther
jhackney1972
Take at look at message 6 in this post.  Easy to try and probably your solution.  Set your graphics to DirectX 11 and restart Fusion 360.
John Hackney, Retired
jkoturner
Brilliant. Thanks that was indeed the problem.
I went to preferences and changed the graphics driver from open GL to Direct x 11. Not sure why it had defaulted to open GL though...
Cheers,
James.
Steven_Gao
FYI. This problem has been fixed on the latest update(2.0.13881). Please update Fusion 360 to latest version.
