I've been using fusion for four days. The last day or two I've been having a problem with the graphics display freezing., I don't know what term to use but I'm talking about the image of the model that you can pan, rotate, etc. When that freezes the rest of the UI still responds properly, except for the view selector cube in the upper right. When you hover over the cube you can see the cursor change but that's all. It doesn't respond to any click. I assume the parts that quick working use a different graphics mode.
When I restart the app it all works again. The amount of time I can use the app has been decreasing. It is now only a few minutes which makes the app useless.
I'm running windows 8.1 pro on a Dell latitude E6500 laptop. The OS was installed from scratch recently. The dell website says my drivers are the latest.
What should I do next?
