Hi @developmentMV8W3
To confirm - you used the NVIDIA steps in that article, correct? I think my link highlighted the AMD section for some reason, but I would recommend going through everything in the 'Windows' section (power options) and in the NVIDIA section (run with... when opening Fusion). I'm particularly interested in the 'run with' option and what happens when you select that. Anything?
I had a look through the logs, and while the Fusion side isn't giving me much (I could have sworn it would tell me what GC was being used..), there is an interesting repeating error in the Windows logs related to drivers. This occurs on 6/29 at 12:53:06
Event[0]:
Log Name: System
Source: Intel-SST-OED
Date: 2022-06-29T12:53:06.5930000Z
Event ID: 19
Task: This task logs error codes to system event log.
Level: Information
Opcode: Opcode for FW and Driver errors.
Keyword: N/A
User: S-1-5-19
User Name: NT AUTHORITY\LOCAL SERVICE
Computer: DESKTOP-O4IKHO5
Description:
Check the remaining resource budget. Module exceeds resource budget, failed to AllocateFwCps, STATUS = Insufficient system resources exist to complete the API..
And in the Fusion logs, we see this at the exact same time:
20220629T125305 I .4088 OGS Device: VirtualDeviceDx11
20220629T125306 I .4088 Running Add-In Name:100KGarages Path:***/Local/Autodesk/webdeploy/production/59c8a288d74003935db5128cd3acb5349f9d794a/Api/InternalAddins/100KGarages/100KGarages.py Internal:1
20220629T125306 I .4088 Running Add-In Name:ElectronicsPackageGenerator Path:***/Local/Autodesk/webdeploy/production/59c8a288d74003935db5128cd3acb5349f9d794a/Api/InternalAddins/ElectronicsPackageGenerator/ElectronicsPackageGenerator.py Internal:1
20220629T125306 I .4088 Running Add-In Name:parts4cad Path:***/Local/Autodesk/webdeploy/production/59c8a288d74003935db5128cd3acb5349f9d794a/Api/InternalAddins/parts4cad/parts4cad.py Internal:1
20220629T125306 I .4088 Running Add-In Name:traceparts Path:***/Local/Autodesk/webdeploy/production/59c8a288d74003935db5128cd3acb5349f9d794a/Api/InternalAddins/traceparts/traceparts.py Internal:1
20220629T125306 W .4088 MessageBox Warning: The software renderer is being used; it could be due to that the graphics card is not powerful enough or its driver is not installed
So thi sis indicating to me there is a problem with either the graphics card or Fusion running with the correct card (since we're seeing Intel card issues). This thread has a few suggestions, seems it could be related to a particular Dock or Sleep timer.
For now, I'd love to see the results of 'run with' - when you use that, does Fusion launch? Can you access the graphics diagnostic and see what GC is shown there?
Cheers,
Karina
