Glitch in decal
colesavatar
Glitch in decal
colesavatar
Hello. I am trying to apply this decal to the front face of this layered map that I'm making in fusion. For some reason, much of it is cut out when the lake is cut out of the top layer. Attached are the fusion files and the image decal I'm trying to overlay. Thanks in advance.
Phil.E
Decal does not like "holes" under where the manipulator is positioned.
A couple things can be done here.
First, do not edit the decal using the timeline. It causes a freeze that I'm logging as a bug.
What I tried:
1. Delete the existing decal from the browser folder
2. Add 1 inch of material all around the cutout
3. Insert the decal, un-tick "chain faces". You do not want to chain faces at all here.
You might find that adding an inch or more around the shape allows the Decal logic to overlook the hole in the middle.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
colesavatar
Thank you for the reply.
