Announcements
Glitch after latest update
keiranjenkins6TUH2
Observer
keiranjenkins6TUH2
Observer
Observer
Good Morning,
Myself and other colleagues have been experiencing a glitch with putting components onto existing pages of drawings after the last update.
When selecting Design>Drawing>From Design  Contents: Select  Representation:Folded Model or Flat Pattern
It will only work when creating a new sheet. When putting onto an existing sheet it glitches and you loose the flat pattern transferring over.
Any ideas?
Cheers Keiran
Replies (8)
keiranjenkins6TUH2
Observer
Observer
Same as problem reported by andygriffinp6zt8
nemadec
@keiranjenkins6TUH2
Apologies for inconvenience, We have already logged the issue.
We will be resolving this as soon as possible.
Chandrashekhar Nemade
Sr. SQA Engineer
Pramod.kadam
Hi @keiranjenkins6TUH2 ,
This is known issue. We are working on to resolve this.
Please use following workaround:
While creating drawing when you switch to drawing workspace; just click once on the Fusion application top bar, then you will see the view attached to the cursor. And then you can the view in the sheet.
Pramod Kadam
Product Owner
Fusion 360 Drawings
seba079
I'm glad to see this issue already reported and acknowledged, as it has been bothering me for the past few days.
I'd like to add my own workaround to this bug: I create the flat pattern on a new sheet; create another flat pattern on the intended sheet; then remove the new sheet. This hasn't failed me yet.
keiranjenkins6TUH2
Observer
Observer
Do you have a screencast of suggested workaround @Pramod.kadam I have not been able to get this work around to work.
keiranjenkins6TUH2
Observer
Observer
Have you found at workaround for putting folded components onto an existing sheet with flat pattern already? @seba079
Pramod.kadam
Please check if this helps.
Pramod Kadam
Product Owner
Fusion 360 Drawings
nemadec
@keiranjenkins6TUH2
please find the video for work around which @Pramod.kadamsuggested.
Sr. SQA Engineer
