Getting update error
Message 1 of 1
Log below for today, apparently the update is failing, I havent opened this in ages so I suspect I am well behind on updates.
2020-08-01 20:14:39,296 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2020-08-01 20:14:39,298 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing incomplete packages
2020-08-01 20:14:39,311 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.process - INFO :: Primary app is 73e72ada57b7480280f7a6f4a289729f
2020-08-01 20:14:39,312 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.process - WARNING :: Exception in Update <urlopen error <urlopen error [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:720)>, url:https://dl.appstreaming.autodesk.com/production/97e6dd95735340d6ad6e222a520454db/73e72ada57b7480280f...>
2020-08-01 20:14:39,312 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2020-08-01 20:14:39,314 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2020-08-01 20:14:39,314 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2020-08-01 20:14:39,314 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2020-08-01 20:14:39,315 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x7fbbc91b7e80> #
2020-08-01 20:14:39,315 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2020-08-01 20:14:39,315 - MainProcess(2261) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2020-08-01 20:15:36,124 - MainProcess(2261) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating osx platform object
2020-08-01 20:15:36,125 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2020-08-01 20:15:36,125 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: # #
2020-08-01 20:15:36,125 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x7fbbb2607940> #
2020-08-01 20:15:36,126 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2020-08-01 20:15:36,126 - MainProcess(2261) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: /Users/JARVIS/Library/Logs/autodesk.webdeploy.streamer.log
2020-08-01 20:15:36,126 - MainProcess(2261) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from /Users/JARVIS/Library/Application Support/Autodesk/webdeploy/production/3e75c09e67301f3c0dd03e3380981262d7254a9c/Autodesk Fusion 360.app/Contents/Libraries/Neutron/resources/buildinfo.json
2020-08-01 20:15:36,126 - MainProcess(2261) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2020-08-01 20:15:36,126 - MainProcess(2261) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2020-08-01 20:15:36,126 - MainProcess(2261) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20180605074311
2020-08-01 20:15:36,176 - MainProcess(2261) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2020-08-01 20:15:36,177 - MainProcess(2261) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: /Users/JARVIS/Library/Application Support/Autodesk/webdeploy/production/3e75c09e67301f3c0dd03e3380981262d7254a9c/Autodesk Fusion 360.app/Contents/Libraries/Neutron/resources
2020-08-01 20:15:36,177 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2020-08-01 20:16:14,083 - MainProcess(2261) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating osx platform object
2020-08-01 20:16:14,085 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2020-08-01 20:16:14,085 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: # #
2020-08-01 20:16:14,085 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x7fbbaec5aba8> #
2020-08-01 20:16:14,085 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2020-08-01 20:16:14,085 - MainProcess(2261) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: /Users/JARVIS/Library/Logs/autodesk.webdeploy.streamer.log
2020-08-01 20:16:14,085 - MainProcess(2261) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from /Users/JARVIS/Library/Application Support/Autodesk/webdeploy/production/3e75c09e67301f3c0dd03e3380981262d7254a9c/Autodesk Fusion 360.app/Contents/Libraries/Neutron/resources/buildinfo.json
2020-08-01 20:16:14,086 - MainProcess(2261) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2020-08-01 20:16:14,086 - MainProcess(2261) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2020-08-01 20:16:14,086 - MainProcess(2261) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20180605074311
2020-08-01 20:16:14,161 - MainProcess(2261) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_GB
2020-08-01 20:16:14,162 - MainProcess(2261) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: /Users/JARVIS/Library/Application Support/Autodesk/webdeploy/production/3e75c09e67301f3c0dd03e3380981262d7254a9c/Autodesk Fusion 360.app/Contents/Libraries/Neutron/resources
2020-08-01 20:16:14,163 - MainProcess(2261) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
Replies (0)
