Hi, I currently have a linked component in my design called Racecar that I use as a reference.
After I made some changes to the linked component in its original file, I tried to click "get the latest milestone version" in the Racecar file.
The linked component does update to the correct design, but some of the bodies in the Racecar file gets removed or edited. The time line also shows many red and yellow boxes after updating. Please help me.
“The time line also shows many red and yellow boxes after updating” it means there are some errors and warnings for the downstream features. These influenced features should be dependent on the link component/referenced file. You should review the process of how to create/define the features and some of the inputs may be lost because of the update. If the update is necessary, you need to correct the errors manually. If possible, you can share the design file in here and we can take a look.
