Fusion Support
Geometretric pattern function not available on imported geometry?
2 REPLIES 2
nicolas_meiresonne
82 Views, 2 Replies
Hi all,
I noticed that the Geometric Pattern function is not available/showing when I upload and open a STEP file into Fusion 360. Am I correct to assume that this Geometric Pattern function only works on geometry that is build inside Fusion 360?
I have the product design extension active and I'm able to use it on a simple plane when creating one in Fusion360.
Would be nice if this feature would work on imported geometry as well.
Thanks for your help!
Nicolas
2 REPLIES 2
When importing designs in formats other than f3d, the design history is deactivated by default.
Activate Design History.
günther
Got the issue fixed! Thank you
