Announcements
Generated toolpath different depending on the WCS reference point
regis.priqueler
regis.priqueler
I got a 2D adaptive on a setup where WCS origin is position in the top middle of the stock. And it generates as intended. But fi I change the position of the origin to the middle bottom of the stock it generates differently and the result doesn't make sense.
I duplicate the first toolpath to be sure they have the same settings.
Middle top
 then middle bottom
seth.madore
Well, that's not supposed to happen. However, I have started to see a lot of 2d issues flowing back to WCS location as the cause.
Could you share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
regis.priqueler
Hi, Thanks for your answer, here's the file
