Announcements
G2 constraint for 3d sketch spline
mikkoYWYF7
Message 1 of 8
mikkoYWYF7
Trying to learn Fusion and having hard time with 3d sketches.
Is it possible to have a g2 connection along Y-axis and still keep corner on Z-axis? Curvature constraint affects both axis. This is between 2 spline sketch.
Thanks.
Replies (7)
Message 2 of 8
g-andresen
what do you want to achieve? > show real existing object
günther
Message 3 of 8
mikkoYWYF7
Here´s couple of pictures. trying to get smooth side along Y-axis and stil keep that corner on Z-axis.
Message 4 of 8
g-andresen
please share the file
File > Export > save as f3d on local device > attach to next post
günther
Message 5 of 8
mikkoYWYF7
Here´s the file.
Thanks.
Message 6 of 8
jeff_strater
yes, you can do this.  To keep the corner on the z axis, create a construction line along the z axis, the constrain the point to that line using Coincident.  Then, just add a Curvature constraint between the two curves.  If you want one of them to react to the other, you can Fix the tangent handle of one of them.
Jeff Strater
Engineering Director
Message 7 of 8
mikkoYWYF7
Thank you. This helped. It´s still impossible to get the shape I would like to. Those Bezier handles are pretty useless.
Thanks.
Message 8 of 8
jeff_strater
For a 3D spline, the handles can only be manipulated using the Move command.  You cannot just drag them, unless they are 2D splines in the sketch plane.
Jeff Strater
