G-Code does not run as expected with Mach 3. Z Axis issues
Hello all, I am new to the CNC community an am stuck on what you might think is a simple problem.
I'm using F360 v. 2.0.7438, Mach3 v. R3.043.062 on the SainSmart Genmitsu CNC Router 3018-MX3.
I am trying to engrave on a curved surface of a pad-lock.  Everything seems to run correctly in F360 simulation, but when I start it in Mach3 my Z-axis plunges into the material, goes to its starting point, engraves the numbers (which appear to be at the correct height) then plunges again to my CNC machines zero points.  I Ref All Home before I start and use the Auto Tool Zero for my Z-axis.  I've attached my F360 project and some screenshots.  I feel it is a simple fix that I just can't figure out.  Thanks in advance for your help.ABUS 72/40 LockABUS 72/40 Lock
MoshiurRashid
This is our manufacture group. You may find a solution here:
https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
