Announcements
g code and the WCS
tom
g code and the WCS
tom
When I view my g code on a part that is 10 inch long and all the cutting I am doing is in the 5 to 9 inch x range.  The G code seems to start cutting at 10+ inch X.   I chose a WCS location at the top left corner.  My assumption is that would be the zero point for the G code to start is at the WCS?  Screenshot 2021-09-02 083816.pngScreenshot 2021-09-02 084026.png
seth.madore
It looks like you're using a Turn/Mill post, is that intentional? Can you share the Fusion file and describe what machine and controller you have on the shop floor?
Seth Madore
tom
I am using a Haas TM 2P
tom
I could get that option to post a Gcode the machine simulation do not work
seth.madore
You need to use the Haas NGC post (assuming you have the NGC control) for mills, not lathes
Seth Madore
tom
Thank you !   That did the job.
Tom
