Fuzzy Letters in Text Tool
bmsteve.au
bmsteve.au
Hi There all, Just started in F360 and have been using the text tool, when I create text it's just a fuzzy bitmap and not vectors, can't tell if it's my fault ?
Doesn't matter what font I use, the sketch is closed as well
I've done this several times also shut down the program and restarted the PC
Windows 10
Processor AMD Ryzen 9 3900XT 12-Core Processor 3.79 GHz
Installed RAM 32.0 GB
System type 64-bit operating system, x64-based processor
Thanks In Advance
Accepted solutions (4)
jhackney1972
You are still in the sketch.  Finish your sketch and create a feature (extrusion, revolve, etc.) and you will get your sharp model.  You can also right click on the sketch text and chose Explode Text if you want vector text elements.
John Hackney, Retired
jeff_strater
Fusion does not convert the text to vectors until needed (by Extrude, Sweep, etc).  You can manually force this conversion by selecting the text in the sketch, and choosing "Explode".
Jeff Strater
Engineering Director
g-andresen
take a look at the extrusion or Emboss
günther
bmsteve.au
LOL, I should kick myself, so obvious when it's pointed out
This is what I was trying to do, took me 5 minutes to figure it out once I had the letter I wanted
Thanks for your quick reply's guys 🙂
