Announcements
Fusion360 will not open
guillermo.baselga
Message 1 of 49
guillermo.baselga
I  come to this forum as my last resource, since ive tried everything i could and I just can not get the fusion360 program to work. When the program opens, it launches as normal, but when trying to open the log in, it recognizes the click, but just does not open the browser. Here is a list of all the things I've tried so far:
- Install and reinstall
- Repair the program and Reset the program from Fusion Service Utility
- Reinstalled the AdSSO (and then rebooted)
- Checked the path on "HKEY_CURRENT_USER\Software\Classes\adsk.idmgr\shell\open\command"
- Deleted the "%localappdata%\Autodesk\Identity Services\WebView2" folder
After every single step, I have restarted both the program and the computer, to no avail. I am trully lost, and would gladly take any help i can get.
Ive linked the before and after click on the Fusion 360 app (its in spanish but its just the default messages)
Replies (48)
Message 41 of 49
maxleajimkd
I have a similar problem because when I open it and press login
To log in to Fusion, you need the Microsoft WebView2 component, which is missing from your computer. You can download it directly from Microsoft using the Evergreen standalone installer appropriate for your device.
More information
I followed everything but it appears that it is already installed, what can I do?
Message 42 of 49
RajkumarIlanchelian
@maxleajimkd It likely is an older version. You can uninstall and install the new version and that should help.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 43 of 49
maxleajimkd
I already did it and it didn't help
Message 44 of 49
maxleajimkd
please help me!
Message 45 of 49
rihikit264
Community Visitor
Community Visitor
i removed the key here
so
We've opened a browser window for you to sign in to your Autodesk Account. After you sign in, you'll return here.
Can't find the window?
Message 46 of 49
RajkumarIlanchelian
@rihikit264 Did removing that key work for you?
Autodesk Fusion
Join Fusion Insider
Message 47 of 49
pad_1994
Observer
Observer
This worked for me too - thank you so much. I have been struggling with this issue on and off for months (I gave up on Fusion and stuck to Inventor, then every so often tried again) - I tried every solution I could find, this solution didn't appear anywhere back then. I have just had the same fight tonight, and found this solution. It worked and I am in. Success!!
Message 48 of 49
myakupodef
Community Visitor
Community Visitor
Hello, I have same problem but I don't have this file to delete
Message 49 of 49
@myakupodef Its likely some other issue is causing this then. What OS are you on? Does any solution from the below article help?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Stuck-in-Sign-in-l...
Autodesk Fusion
Join Fusion Insider
