Fusion Support
fusion360 pin hinges
6 REPLIES 6
15205DMCF8
261 Views, 6 Replies
hi there im after a bit of help in fusion360, i have drawn up a small container but i need it to be able to open one side and i was thinking of using some 3mm stainless pins to pass through say 6 tabs, i would also like to be able to lock it shut if possible??
this is going to be 3d printed.
thanks
6 REPLIES 6
davebYYPCU
in reply to: 15205DMCF8
See if this makes any sense.
Might help....
15205DMCF8
thank you i will have a look at that now.
15205DMCF8
in reply to: davebYYPCU
what would be the best way to 3d print this part? can i split it into 2 pieces?
thanks
davebYYPCU
It is already 2 bodies,
Save each body as STL,  for printing, but they need a bit more work for efficient printing,
I didn’t  do any work for locking, because it is still in the idea stage....
The fillets were too big in my view but when with what was given.
Might help......
15205DMCF8
yes i think you're right regarding the fillets, i was just trying to get a round edge on those corners, the part is going to be a tool holding box on a scrambler, putting a tyre iron and a couple of spanners in for my dad. i was putting the fillet so there was no sharp edges at the front, think i would like to put a bit of a lip around the inside of the main body too.
15205DMCF8
for some reason when i drew the first sketch the angle has changed to 62.5 i will get the full dimensions again and start agin
