Fusion360 equations with "percent %" variables don't work as expected
drisler8109
drisler8109
I am trying to create a "scale factor" variable which is then used in a "length mm" variable's equation
I used "modify -> change parameters" and created the following "user parameters"
idScalePercentage - Unit "percent %" - value "5mm / 4.65mm" or 1.07527
percentCancel - Unit "percent %" Expression "100"
m5DiameterTarget - "length mm" value 5mm
m5Diameter - "length mm" Expression "m5DiameterTarget * (idScalePercentage / percentCancel)
Bjanders
Maybe I don't understand your question, if you are saying that you have to create a "cancel" variable to make it work. Or then I can't repeat your issue. For me it works as expected:
If this is not your problem, then please clarify.
drisler8109
I thought it was both "percent %" and "no units" - seems to only be an issue with "percent %"
