Fusion Support
Fusion360 crashes / closes after update
2 REPLIES 2
christian_lehmann8DBCU
122 Views, 2 Replies
Fusion360 made an update today. Before it was running fine.
Now when I (try to) start Fusion, I get a message "Fusion update: you have the most current version" (roughly / translated from german version). The the Fusion window immediately closes. I tried several times--behaves always the same. Rebooting the computer did not help.
Is there anything I can do (besides trying to reinstall the complete program)?
2 REPLIES 2
Hello, could you try to reset with Fusion Service Utility?
Baocheng Wu
SW Engineering Manager
If you do not know how to use the Fusion 360 Service Utility, this webpage will help.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
